Alert When Pack's Aren't Syncing?
Sometimes, tables from packs stop syncing for whatever reason. It’s happened a lot with the Jotform pack (it’s an issue with Jotform’s API, not the pack). But it stops syncing for whatever reason and I don’t notice until I go to check the table and since I’m not checking every single doc every day, I sometimes don’t notice for a while.
Is there a way to set a notification or something for when there’s a syncing issue?
