We use the Coda Forms to enter in interview notes as we talk with outside candidates. In the subtitle of a Form viewer, the text can’t be formatted and line breaks aren’t supported. We use our subtitle space to share links with interviewers to the questions asked, where to find resumes, etc. It would be great to either make that space more flexible, or allow paragraph text to be added as part of the Form view.
You can also create a single column in your table that is defined by formula with all sorts of rich text, bullet points, links, etc
Then make that column visible on the form as a Resources section at the top of your form.
Should work really well! You can use the same method to input images into forms, break lines using rectangle, and so much more!
Here’s some related info
