I tried to build a list of buttons to use as “solo-items menu”, but there’s some displaying issue of overlapping buttons. Do you know any trick to fix this?
Also, I was wondering how could I remove the commas.
Here you can have a look at the example.
I use Firefox, but I’ll look into it… Thanks!
I guess this is only useful if I’m the only one using the doc, right?
cheers
Stylus has firefox version ,but chrome is more better.
you can specific the doc url or domain or specific table, or all table in coda, or … whatever you want.
