When dropdown value in field changes to a certain value want it to automatically click a button on the same row.
Would be nice to be able to change other values in row as well.
hi @Glenn_Shukster , you can an automation to execute that task for you. The first option is row change, that is the one you need
cheers, christiaan
Hi @Christiaan_Huizer, Getting pointed in the right direction helped me solve it. Thanks!!!
