Hello,
I have 3x sample interconnected tables here: Test Docs
The tables represent my own project management doc which are titled: Task, Project, and Employees
Usually, a project involves a standard set of employees, but occasionally more or less can be involved in certain tasks. According to my workflow, I like to put the related employees directly into the project and have that represented in the task via formula. However, occasionally that changes and:
a) not all employees are needed for a particular task or
b) an employee is brought on for a single task.
Is there any way to auto-populate a field (in this case the “people involved” column in the “Tasks” table), but make it changeable (additions/deletions)? Or any other creative solution?
I hope that makes sense. Thanks!
