Hi guy, I am really confused with the Coda moblie interface right now, where can I find the upload file function? ?
Hello @tkykaren233 ,
I am not sure I fully understand your question, but perhaps this helps you: add a column type file to your table. On mobile, you can edit the table row (or add and edit a table row) an the file column allows you to add a file that’s already somewhere on your mobile device. You could also use an image column for the same person. Both columns allow you als to use your mobile camera to upload an image.
Oh so I need to create a col, and then I can add image from the mobile?
Yes, like so (works on mobile, tablet, laptop, pc):
