Hi all, I’ve been searching through the community threads trying to solve a problem I’m having, but haven’t quite found it. I have a feeling it’s rather simple once I get the formula right.
What I’ve set up is a Table with a Column type set to Text. Within the box I inserted /checklist to get the list I wanted. What I would like to do is set up the value of the rows to always have the /checklist every time I create a new row in this specific column. Aka, every time I create a new row in this Task column, it will prepopulate with a checklist, so I don’t manually have to add it to each new row.
My guess is this could be solved by going to Text Options and setting up a formula for the “Value for new rows” section. But I haven’t quite figured out the best formula to do so. Any suggestions?
(Also note: I’m not using the Checkbox Column Type is because it only allows one checkbox and I need multiples in one container.)
