Clearing checkboxes with a single click
Hi,
Is it possible to clear all checkboxes with a single click? Thank you for the help.
attendance%20tracker
Not that I have found. I’ve been copying the value that I want (checked/unchecked), then selecting multiple checkboxes, then pasting that copied value in bulk.
The UX that I always try first (in the hope that it’s been implemented :smiley:) is selecting multiple checkboxes (1x3, 3x1, 3x3) and then bulk changing their values with one command – pressing the space bar, for example. @mallika
Yes — make a button that will update all rows, setting all checkbox column to “false”:
