Hey community! I’ve been thinking about a connection between Coda and the Wordpress plugin “Woocomerce”
I’m actually using an integrator called n8n, but I’d like to know if anyone has a way to share/modify/view data from coda in wordpress.
What I’m trying to do is view in woocomerce a list of products that take the information from a coda table, this way i can keep them updated in case I make any change on my stock list so they automatically change in woocomerce.
Any ideas? let me know if there’s already someone who has done that!
are you still using Coda and Woocoomerece? I ended up with the very same problem and I wonder if n8n is still a solution to automatize updates between Coda and Woocommerce. My most important needed feature is to update stock.
