Coda table as Power BI data source
hi,
as an intro, we r planning to develop apps using coda & wish to use ms power bi for the report dev.
previously, there was already a discussion on this as per link below:
Coda Table Use as a Power BI data source? - Ask the Community - Coda Maker Community
i wish to know the latest dev on this & if there isn’t, can anyone guide me to creating an api to link a coda dbase to power bi, pls?
tks & krgds,
nik
ps.
@Piet_Strydom
HI Nik,
I strictly focus on the no-code aspects of Coda, so am not going to be able to assist with this.
P
Hey @Nik_A_Hafiz, welcome to the Community!
As far as I can see, Power BI can use a REST API as a datasource:
Unfortunately, Coda APIs for reading tabular data (i.e. the GET /rows endpont) returns a rather complicated schema that isn’t easily mappable to just a list of column->value dictionaries. So you either need an intermediary service to filter and convert the data, or implement a different way to retrieve data from docs.
For the former option you can code the server yourself, or you can use Make / Hookdeck / any other service that can transform and forward webhooks.
For the latter option, I actually have a pack in the works that will allow creating custom REST APIs directly out of your docs on top of the Webhook Authomations mechanism:
To be honest, I’m not developing it that actively these days — it’s on the to-do list but not the biggest priority, as it’s quite an effort for not a large demand. I’m open to getting this sponsored though: if anyone’s ready to pay for this to be expedited I could prioritize this.
P.S. Also you can just export to sheets with one of the packs for this, and use sheets as a datasource if Power BI allows that.
many2 tks for replying @Piet_Strydom & @Paul_Danyliuk.
for info, i’m ‘itching’ to move to coda fr notion. this is 1 of the main issues tht probably m trying to iron out to make tht jump.
@Paul_Danyliuk
kindly advise what does the sponsorship entail/require.
tks again & krgds,
-nik
p.s.
for info - my previous inquiry rgdg notion to power bi connex in the weblink blw-
Solved: connecting notion database - Microsoft Fabric Community
