Can we get an option to insert a code block in a specific language through slash command? e.g.:
/html
Bonus points/alternative might be to have a document setting for default code block language.
/html
This’d be neat, I’d also suggest being able to write three apostrophes and then the language though, I think that’s standard for markdown.
Currently a code block is started in Coda by writing three apostrophes, but no chance to write the language.
It even works here in the forum
print(5)
<body><div>hi</div></body>
print(5)
