Color Columns without conditional formatting
Hey,
I want to be able to colour columns regardless of their contents. ie I don’t want to use conditional formatting. I just want the columns to be a certain colour.
With a text column it gives me this option but not with a number column.
Anyone understand the logic behind this?
I can use conditional formatting “Blank/Not blank” but these seems a bit hacky.
Also is it possible to colour the columns headings?
Thanks,
Ian
Hello @Ian_T !
For this kind of stuff, I rely on Format() function, referencing a special table holding the formatting templates.
The downside being that this can only be used for displaying, editable column is separate.
Here is a demo to explain :
Thanks @Martin_Portevin.
Any idea why Text column are Formatable but not number columns?
Ian
Yep, you need to convert it via ToText() for the style to apply. See my updated example
Is there some reason behind you can format text but not numbers?
I guess this is because formatting can only be applied to canvas content. When you type a number anywhere in a page, it’s not seen as a Number but as Text. Numbers are a different type of content, without any additional data for formatting. Pure math data.
Not sure my answer is clear nor true :slight_smile:
