As shown in the image below, I have a table and on top two columns. The problem is that it is not allowing me to extend the width of them so it takes the same space as the table.
coda has replied on the page width issue here…
I have ran some tests, the issue here is that databases do not follow the same pattern as the rest of the blocks, they overflow the width of the content, except when they are part of a column.
If you try to drag some text to the right of a database you will see that the blue guide line appears inside the database and not after.
Hi all, thank you for providing feedback on page layout! We are excited to share we are opening a beta for wider column groups. This is part of an experiment to see how users respond to wider objects in Coda. If you are interested is signing up, you can use this form.
Look forward to hearing from you!
