Loving the inclusion of Maker permissions in the new paid tier, but I feel like one very important option is missing: column permissions. I want the ability to give editors full access to a table, but not the ability to add/remove columns, change column types, or to edit column formulas.
Add that in and I’ll be jazzed.
I’m a dolt. If I would have hovered over the “Interact Only” help icon, I would have learned that “Interact Only” with all buttons on does exactly what I’m looking for.
I wouldn’t be too hard on yourself, this was also confusing for me as well.
On initially going over the locking side bar, I was left a little disappointed and confused.
But as you have pointed out, those ? hovers helped alleviate that.
