I’m looking for a way to combine data from two tables. I found a workaround that I’m happy with, but I’m still working on perfecting it. I have the data pulling into two separate columns (Email Marketing and Push Notifications) and I would like to combine that data into one column if possible, then sort it ascending. Is this possible?
I like the result I’m at so far, but it would be easier for my team to read if it’s sorted alphabetically so the dates will ascend.
How about sharing a (dummy) doc with non-confidential data. Plenty people here willing to help, but is easier and takes less time showing you something in your own doc with data you are using than rebuilding something from scratch.
@Heather_Hart1 ,
I put one of many solutions in your doc. I kept the formatting of dates more or less as you had it - which makes the formula a bit complicated. Many alternative solutions possible.
