Hi community,
What the most compute efficient way, to extract a text part out of a cell?
Ideally, i could set a start point (that should not be included),
and an endpoint that should not be included as well.
Thx,
Marc
Hi community,
Thx,
Marc
HI Isebar
It sounds like Middle() will do the trick. Some examples are on the page below:
Start an end points are also just somewhere inside the cell. So there’s no fixed after some characters, kind of thing. I’m pretty sure I need to combine it with something else, but I don’t know how.
Hey Isebar, perhaps you could try RegexExtract
then?
A bit more information would help…
RegexExtract(thisRow.Name, "START (.*) END", "s").last()
Credit: @Rickard_Abraham
