Convert Lookup values to People Values
Dear Community,
HELP!
How can I convert lookup values (as a result of a lookup column or lookup formula) to real People Value? So I can compare it to User() function?
A See PEople values on the left, but lookup values on the right. How to make the right Peope column look like the left one (People value).
I’ve seen a solution here, but the referenced doc is not available anymore…
Thanks!!
Hey there! People values hold other values within themselves (specifically name, photo, email)
You could do peopleValue.Name and compare that to the lookupValue.name
Hi,
indeed, it helped, THANKS!
Exactly how I solved is:
In the right Column originally had:
[Tanulók].Filter([Értesítésszint].contains(thisRow.Szint)).ListCombine().Unique()
Than, based on your advice I changed it to the following (Név is Name in Hungarian)
[Tanulók].Filter([Értesítésszint].contains(thisRow.Szint)).[Név].ListCombine().Unique()
@Marton_Posz
thank you for sharing your very elegant solution
it helps others who want to do something similar and will find this thread
well done
max
