Hello!
Does anyone know if it’s possible to look up a non-display column? I want to be able to lookup values in two separate columns in a table, but can only currently do a lookup for the display.
Any workarounds?
Hannah
Hello!
Any workarounds?
Hannah
hi @Hannah_Krumholz , happily it is via chaining.
you take the name of the column that contains the lookup value, you add a dot and you see the options you need.
Cheers, Christiaan
This will make it a formula rather than a select list though right?
For more context, I have a list of accounts and contact details - I need the account to be the display column, but I also want a select list of all contacts that we have.
maybe this post helps:
the moment you share a doc with a concrete example, plenty of people are willing to help you out, cheers,Christiaan
