Hi Coda team!
I was happy to see there was a way to copy and paste one table to another doc section (thanks to Mallika’s tip and some other help I found in your Learn section).
I’d like to request two possible features for copying and pasting an entire table:
- Hidden columns should stay hidden (or maybe just alert the user that there are hidden columns that will be revealed after pasting, so the user can re-hide them).
- Conditional formatting should be preserved (it didn’t get copied, so I had to recreate–tho I was impressed that copy and pasting those formulas also worked). Still, if I had a complex format setup I would have liked that to be preserved as well.
Thanks,
-Dana
