Cross doccing comments? (Solution)
Has anyone found a way to create a messaging system that takes comments from a cross docced table and send them to the master table.
Would this be possible using zapier, automations or anything else?
Looking for some cool community examples to overcome this problem. :slight_smile:
Unfortunately there is no way to access comments through API or any other related means.
There’s just one way: to load the doc snapshot file and parse comments out of it. It’s not that trivial to implement though β€” possible but not trivial, and would most likely require a dedicated backend.
I was looking into this and had the intention to implement it but only after I deal with more urgent stuff.
