Custom Barcode Scanner?
Is there ANY way to scan barcodes into Coda? Is it possible to build a custom module for Coda?
Dear @MK_2109,
I recommend to check out this post and the doc Ben published where you will find more material.
In case you have some more specific questions, this community is a good resource and others might have gathered experience and are able to support you.
Thanks @Jean_Pierre_Traets. I saw the QR Code doc, but I don’t think its applicable to my case. Specifically, order picking where a picker scans the product to trigger the backend workflow. Am I understanding correctly?
