I have a Google Sheet that I’d like to move into Coda. The name column is text that is linked to the persons profile. If you cut & paste the Sheet into a Coda Table the name comes through a just text without the link. There are hundreds of rows so doing it manually is not an option.
Is there a way to do this? An importer I haven’t seen, a format I could set in the Sheet that will allow me to cut & paste?
