Using tables would be a little more convenient if it were possible to add a description to the table or column.
@Nurlan_A Hello,
You can add a description in a canvas for example like any other element of a page that would allow you to indicate the information you want.
Sincerely,
Thierry
Thierry,
I have a use case that is not quite met by your answer to the above question. I would love to be able to have metadata and a schema (ERD) that helped me find existing resources (tables) in more of a file folder hierarchical manner.
Eg my outer most layer could be Department (CX vs UXR vs data science, etc), then within department i select team. I can operate at the level of granularity that makes sense for the tables metadata classification (some should be organization wide, some department wide, etc). That way, when I want to reference a table that I suspect exists (eg CX Sprint Planning) but don’t know the exact name of, i can do that heuristically in the “schema browser” pop up that comes as the dialogue when I want to add a view somewhere.
I’d be excited to talk more if this is of possible interest but not quite making sense!
Sarah
@Sarah_Heyborne
Hello Sarah,
I understand better now what you want to achieve. However, at my little level of expertise and to my knowledge, except for the use of a formula with a filter or even the use of an interactive filter on a specific table or column, I don’t have any other idea in mind but I will look for some on my side to help you the best I can
Sincerely,
Thierry
