Can we please get an option to disable auto suggestions for number fields as well?
Currently, these auto suggestions make it easy to enter wrong data. In the second screenshot below, if I was to hit Enter, Coda would input 346.62 instead of 34.
An impractical workaround is to change the column type to text, but then I have to specifically ensure that this data is calculated as a number in concerned formulas.
Please make this:
To prevent this:
Thank you!
