I am in need of the collective wisdom - I can set a filter on a lookup column that will filter the potential values based on a single entry in another column. E.g. to discriminate between hot and cold beverages. (Filter column beverage type = Hot will only allow drinks with beverage type hot. Hot coffee, and not Ice Coffee. )
Can it be setup where the filter column has multiple entries. E.g. a tag column where I want in the lookup column to show me all articles related to tables and canvas columns, but exclude the ones on buttons.
In this case, I assume we can find a given tag only once in your table, the find function should check all the tags as multiple entries
And I dont see why I couldnt make any “AND” condition as I want, as we would do directly in the main table
