The Filter Bar appears to only be returning the option to select quantities between 0-100, even when the quantities are (much) greater.
(these quantities go into the billions)
It doesn’t appear to be configurable in the filter bar menu.
(Or am I doing something very wrong?)
Is it possible that the data values in the table are currently between 0 and 100? I think the range of the slider is gated by the range of possible values in the table itself.
Unfortunately no; there’s loads of information in the column well outside the 0-100 range
Hi @Billy_Jackson ,
Do you have a doc you could share that has this issue? I’m not able to reproduce this problem when I try to set up a similar scenario.
In the meantime: as a workaround, you should still be able to type the desired values in the fields below the slider.
-Paul
Just PM’d you, thank you!
