I have a list of devices with corresponding operating systems (devices have multiple entires- one for each OS supported). I also have a list of app versions that are supported on certain OSes on certain devices.
I have a control (multiple select) that has a list of devices (filter_device). I then made a control (mult select) of operating systems that filters based on the device selected (filter_OS). So if I choose iPhone for filter_device, only the iOS versions are listed in filter_OS.
I have a table with device, os, app version all listed. I am able to filter the table based on filter_device without any issue. The issue I am having is filtering a table based on filter_OS. I don’t think it likes that I am trying to filter on something that already is a filtering control.
Any ideas? I like the idea of filter_OS only showing the relevant OS versions, but then I cant use that control as a filter for my table, which I need.
I’ve built some complex filtering systems, so I’m confident that what you want is doable. If you want to share your doc or a mocked up sample doc, I’ll jump in and take a look at it.
