Is there a way to use a formula to filter when the count of tasks related to project is 0?
Hello @Sam_Grewal!
You you can add this formula to the projects table in a new column as shown below
Tasks.Filter(Project.contains(thisRow)).count=0
This would get the count of all the task the project contains, regardless of stage and compare it to zero
If you want to count only tasks in a certain stage you could use the next formula
Tasks.Filter(Project.contains(thisRow) and [Task stage].contains(“Not Started”)).count=0
