I have a table that lists persons and their activity statuses. I’m currently creating another table that pulls those 2 pieces of info. When I create a filter based on the person’s status in this new table, it’s filtering correctly for some, but not for others. Not sure what I’m doing incorrectly here…
The Coda controls that you create have to be “connected” to a View in the “Filter” option (you can see this when you hover over the table)
When you have multiples table views, you can hook them up to a customized assortment of controls. Maybe one of your table views doesn’t have the user controls set up in its filter?
