How do you select and copy all the data in a single column using a formula?
please see doc below.
ive done it so if you wanted the info on a page/canvas or in a column.
but in general, its usually just the Table then a dot then the column.
depending on the column type and what you wanted the output to be, you may need to chain .ToText() etc to the end of the forumla.
hope this helps!
Cheers!
Mel
That was a quick response. That was just what I needed. Thank you!
