I set up a table in my Coda doc for Meeting Notes. One of the columns I have is for “Raw Transcript or Notes” from the Meeting. I then have another column which uses Coda AI to Summarize the “Raw Transcript or Notes” column, and a second column which uses Coda AI to “Find action items”.
Unfortunately, after adding two 30min Meetings to the table, I have run out of AI Credits. ![]()
After having learned a small bit about Coda’s recalculations of columns like this, I feel like the better solution is for me to have a Button column that will trigger the AI summarization and action item extraction, or some similar manual trigger for a single Meeting that I add/edit.
Unfortunately, I’m not seeing any formulas to leverage in my Button configuration to do this AI work - am I missing something?
Please help! The only recourse I see is to do this AI work outside of Coda, or on a single page where I can do this on-demand in a text field, once, and then copy/paste into the Meeting Notes table, and both of those solutions feel less enticing to me.
I also wish that the amount of credits was greater, or there was a way to connect my own ChatGPT account, which has more tokens available to me, with my Coda account so that I don’t blow through my Coda AI credits so quickly.
Thanks in advance.
