I’m learning Japanese and was getting frustrated about having to alt-tab between different tools and references, so I built a little tool
It has:
formulas built in for all hiragana, so you can generate hiragana text without switching language and keyboard
Google translate lookups for entered text, plus generated Google Translate audio urls that link directly to audio of your entered text
Because I’m still learning the characters I wanted to see them big and color coded, so I played around a little with the hidden _color formula, and using format() to force header-sized text in formula outputs. It makes for a fun looking doc (esp in dark mode).
Would love feedback and suggestions for improvements!
That is very impressive, but honestly I don’t see it being faster than just switching the keyboard to Japanese (single keypress on some devices, a two-key combo at most) and typing directly…
I didn’t know Google Translate let’s you make it pronounce things via a custom URL! Good to know.
I don’t think it’s so on Windows, but on Mac you can click alt+esc to have the system pronounce any text in any language. You can also download high quality “Siri” voices.
And good luck with learning Japanese. I recently spent 4 years in the country, and loved it. Except that work was so all consuming I never got to learn the language.
The best I can do is konitciwha, and ichi ni san yong go…
