Is it possible to move a Card from one page to another? I have created each page for each team and I want tranfer the project to another team which I want to move card to another page of that team. Is this possible?
Yes, this is possible if you set up your rows properly. Cards are a way of viewing a table. If your cards (or rows) have a column that specifies the team, you can show a view of this table on each page and filter it to only show the ‘cards’ of the appropriate team. When you open a card, there should be a select column/field where you choose the page/team on which you want this card to show.
So, you only need one table for all projects.
