Move cards between Kanban projects
Hi, can I move cards between Kanban projects? I have a sales project Kanban and want to move lost and completed sales to a different place so I can monitor them - doesn’t need to be a Kanban. Is this possible?
Thanks, Kelsey
Hi Kelsey, and welcome to coda.
I have two solutions for your problem, the complicated one, and the easy one, using all simplicity of coda
1 - Complicated One
Moving a kanban card is equal to modify a row of a table, and then you can use automations to track this and run actions.
let’s have a look a consider a task table for kanban (Table A) and a second table for done tasks (Table B)
You want to automatize stuff when row is changed, checking status property go to “done”, for example. Then create an automation like this :
When
Row changed, table A, Column Status
Condition
Do the automation only if the card moved go to done → thisRow.[Step 1 Result].Status="Done"
Actions
Two different actions to simulate the movement of the card :slight_smile :
1/ Adding a row in Table B
2/ Deleting the moved card in Table A
For that use : RunActions(AddRow([Table B], [Table B].Name, thisRow.[Step 1 Result].Name, [Table B].Status, thisRow.[Step 1 Result].Status),DeleteRows(thisRow.[Step 1 Result]))
2 - Easy Solutions > My Favourite <3
Another easiest way to do this is to use the same table (Table A), and use filtered views according to your wish
  • First View : Filter Status different from “done”, but keep the column “Done”, so that you can move your cards, that will disappear
  • Second View : Filter only done status, to see only finished tasks appear
CPT2210101549-1001x645
Please tell me if it’s OK for you or if I misunderstood yout point.
Quentin
I agree with your recommendation of the second option.
In general people are FAR to quick to create new tables, which just unnecessarily complicates life.
Hi Piet !
Indeed that’s what I called the “simplicity” of coda.
It’s amazing to see what you can achieve by creating only a very limited number of tables. I would always prefer to work with a giant table, and process complex filtering, than creating new tables.
In @kelsey_smith use case, it’s even more logical considering that the type of data is the same (A sales project is still a sales project, even if done, and it’s always useful to be able to find back your data later.
Dont delete data, filter them -Me :wink:
Hi there, thanks for your advice.
What I wants is a second table with all the done jobs in them.
So what I’ll do is duplicate the table and then use filters as you suggest.
Duplicate, or create a view?
Create a view - thanks
