Hi! I’m trying to turn a single row green (using conditional formatting) ONLY IF all cells in that row are filled in (i.e., once the record is complete).
How can I do that?
How can I do that?
hi @Rai_Cornell , welcome to the community
I suggest to count the columns. When a column contains content is seen as 1, if not nothing
When you add columns, you have to adapt the condition.
I hope it helps, cheers, Christiaan
BRILLIANT!! That worked! Thank you so much, Christiaan!
