Hi @Jean_Pierre_Traets ! Thanks, but I’m afraid that’s not quite it.
I’m probably confused because there are fruits in the vegetable table as well.
The point is how you can convert a text enumeration of objects, to a lookup
I’m not sure I understood exactly what you were after but I added two columns to your Catch to Vegetable list lookup to show you how. But it really is not optimal.
Could you explain a bit more the flow you are trying to model ?
