Hey! I’m trying to create a button (per table row) that can swap the the row’s column B value with the same row’s column C value (and vice versa).
I’ve set the Button’s Action as Modify Row, Apply to as This Row.
What do I type in the Update Values part of the Button Options though?
Thanks a bunch!
Hey @Steelworld_HEAD,
I wasn’t sure if it just works without a “buffer” column, but looks like it does: You just have to enter the respective other column name. Don’t forget “thisrow” before, so it only fills the current rows value and not a collection of the whole column.
Hope that answers your question
