็How to make click to call button with "+" or leading ZERO in it
Hello. I have created button with click to call
my phone number country start with “0” or “+66” or else it would not work
When I created button to call, the leading zero was missing from my caller.
So i tried to put +66 (Country code) with concatenate instead.
now when i press call button, the “+” is missing.
both way, i couldnot call out
is there any way to fix this?
you can have a look here : How to Coda Calling and Texting?. Set up calls and send messages directly… | by Christiaan Huizer | Medium
enjoy, Christiaan
Hi @Christiaan_Huizer , thank you very much. I am able to make a click to call from this formula. cheers
great, could you as a next step mention my contribution as solved so others with a comparable question can benefit as well?
