How to only show top 10 best clients?
Hi,
I’m trying to show a bar graph of the Top 10 Clients from a table. Here is my logic and first steps:
  1. I have a raw database with clients and revenue
  2. I add a column with a formula for “Accumulates Sales”
  3. I then filter the table to only show unique clients and their accumulated sales.
  4. Then I’d like to create a graph to only show top 10 clientes. I tried to use Slice () but it doesn’t work.
I’m stuck and it’s not working… any ideas?
I think it’s not working because: The Slice() formula filters every row in the table and not only the unique client values.
Here’s the doc: Show top 10 clients?
hi @Hector_Reyes , I am a bit short in time, however this part may help you:
thisTable.Filter([Accum. Sales].Contains(thisRow.[Accum. Sales])).First().Contains(thisRow)
and to slice it up:
thisTable.Filter([Unique values]=true).Slice(1,10)
the next step is using this column in a graph, hope it helps a bit, cheers, Christiaan
and this is the view
the formula behind is:
thisRow.[Unique values] = true and thisTable.Find(thisRow) >= 10
The slice() is good as part of a calculation, not so much to create the visual you had in mind, that is the result of a filter.
Enjoy, Christiaan
Wow!
Thank you so much @Christiaan_Huizer!
Hi @Christiaan_Huizer ! I’m trying this out but it’s not working, don’t know the exact reason why but I’ll hopefully get back soon
did you see this part :slight_smile:
so the filter is right up
what you do is create a new view of the table and this table you turn into a chart
  • you have table 1 with the data
  • you have table 2 with the filtered view
  • you have the chart based on table 2
does this help?
Thanks again for your comments. I couldn’t make it happen with those formulas, it seems that the filters overlap from the raw data table.
But, I found a workaround with some help from support:
1.- Transform the “Client” column to Lookup
2.- Create the Lookup table with “Clients”
3.- Add a “Accum. Sales” Column
4.- Use a filter on that table to only show top 10 →
thisRow.In(thisTable.Sort(false(),thisTable.[Accum. Sales]).Slice(1,10))
I made a “Option B” page to show how it works:
Let me know what you think! Thanks!
