Bug on launch:
When you save your Coda home doc page to a Home Screen icon from inside Safari (because the mobile experience is such a pale shadow of the browser version.) instead of loading the page with the properly cached auth credentials, it takes you back to a log in screen with no browser controls. With two factor plus Google log in, that turns into 6-7 steps and 20 seconds of delay for something that should be instant with one touch. Very frustrating.
This happens even after deleting the Coda app.
Oddly, if you just click on a bookmarked link from within Safari, it loads the proper doc page with no problem.
Anybody found a work-around? Fix from the Coda team?
