I’m trying to create a button that would sync the lookups.
For an instance, if project_select is empty but there’s something in project_lookup (like for Viability Report), I’d like to copy the name in project_lookup and paste it in project_select.
ideally, I’d be able to simply add a project via project_select and have it populated in the project_database and show up next to it in project_lookup (like for Sports Complex).
Hey Shiraaz, thanks for reaching out! I think this is possible to achieve with a button using FormulaMap(). I’d imagine the button formula would look something like this:
// For every row in tasks table where project_select is blank and project_lookup is not blank
[tasks].Filter(project_select.IsBlank() AND project_lookup.IsNotBlank()).FormulaMap(
// Update project_select to match project_lookup
CurrentValue.ModifyRows(
project_select, CurrentValue.project_lookup
Formula w/o notes:
[tasks].Filter(project_select.IsBlank() AND project_lookup.IsNotBlank()).FormulaMap( CurrentValue.ModifyRows(project_select, CurrentValue.project_lookup) )
