Detail view is useful in a lot of desktop scenarios.
However, it is almost wasted on mobile version. Data cannot be displayed in a convenient way (not wide alignement), and what is more important: search box is not present
If you want to filter a row using mobile app, you have to use a interactive filter control. It’s a workaround, and not a very efficient one in mobile beyond some dozens of rows.
It’s a pity that detail view is not properly rendered on mobile app. Codans, do you plan to change this?
Thanks in advance
