Issue with Numbers Formatting
I have a simple numbers column, no formulas. It was a simple float (decimal of 2), which was then visually formatted as Currency using standard Coda column type functionality.
Recently I noticed that it no longer formats it for these numbers (no matter the formatting choice). Anyone know if this is a known bug or how to fix it? It doesn’t affect the formulas relying on this field but it is annoying.
Yes is bug i think.
I have 2-3 documents that also got stuck because they require a “,” and not a “.” ^^’
Related topic
