I have another user case for DetectLanguage() method inclusion on Google Language Pack
Let’s say that I capture in a table text entries in different languages. Depending on the language, the row would be treated differently. For instance, there could be a select list language column which value would be selected using DetectLanguage().
As Coda is going to be more and more used in multilingual environments, the integration of this method would be equally useful
