Roll call! We have another list of exciting improvements that are making your most common workflows even smoother.
Here’s what we launched:
Customize your page and table notifications.
If you want more granular control over your comment subscriptions, go to your ‘Notifications’ menu and unsubscribe from all comments. From there, you can click on ‘This page’ to subscribe or unsubscribe from comments on your canvas content, such as Coda building blocks, or tables.
You can also turn your table comments subscription on and off from the table options menu to cut down on noise or turn up the volume in your tables.
It’s 17:00 somewhere.
We now respect a 24 hour time format in calendar views, so you won’t see your calendars switch to a 12hr time format if you selected the 24hr time format in the calendar options.
Dropdown menus are more visually helpful.
We added checkmarks to the side of list items in a dropdown menu, so its easier to see which items are selected. Also, if you are choosing items from a lookup, we show the lookup chip colors in the dropdown menu so what you select matches its formatting in the original source.
Better use of multi-select lists in pages.
We Marie Kondo-ed multi-select lists in pages, so they look clean and run smoothly when many items are selected.
No need to commit with select lists items.
We made it easier to unselect items in single and multi-select lists. Need to unselect an item in a single-select list? Just choose ‘Blank’.
Want to unselect a group of items? Click ‘Clear’ at the bottom of the list.
More menu options for cards.
We made the menu options for Card views and table views more consistent. Now, you can ‘Collapse all groups’ and ‘Expand all groups’ of cards from the menu options, just like you would in a table.
Check out these docs to see how these improvements make everything from a project tracker to a team hub even better.
