It’s been a busy few weeks at Coda, as our team has focused on helping you make your docs cleaner and easier to organizeーwith infinitely nested pages, collapsible content, expanded drag-and-drop capabilities and outlines for your pages. I’m excited to share today that we’ve removed another constrict on how you organize your docs: now, you can customize the title size for your tables and views.
Previously, all table and view titles were H2-sized headings. This meant that tables and views would get rolled-up into collapsed H1-sized headings, get left behind when H2 headings they were meant to be a part of were dragged-and-dropped to new locations, and always sit in the same part of your page outline hierarchy.
Now that you can customize the size of your table and view titles, you can position them appropriately within a Page’s hierarchy and no longer worry about them behaving like outliers when you collapse, drag, drop and outline. For example, if a table is meant to collapse under an H2-sized heading, simply make the table title sized H3.
To change the size of the title of a table or view, select the title and then choose the correct heading size from the paragraph styles dropdown in the toolbar.
Some other tips for resizing these titles:
- Titles will still default to H2 unless you take action to resize them
- Tables and Views will observe the selected size (heading style) whether they are visible or hidden
- If you’d like to resize a title that is hidden, you’ll need to unhide it first (you can also hide it again later)
- Tables and Views are indicated with icons in Page Outlinesーthis is a great way to quickly see how you’ve sized them in your docs (especially if titles are hidden)!
And, of course, if you simply want your titles to be a little bigger or a little smaller, you can do that too.
