truly fantastic, one of those things i always wanted but never remembered to ask. ty!!
What would be really helpful, and improve functionality a lot would be ability to duplicate columns to different table in the same way you can now duplicate column inside a same table. That’s something that I find missing a lot while building new docs and tables.
Even better would be ability to make a “template” column, like some other solutions have, and reuse it across the platform. This would help quite a lot, because there are lot of columns and setups that are same across documents (task/project statuses, sectors inside company, team names, just some examples), but are not same in whole structure so you cant utilize the new custom template feature for whole document
Is it possible to copy column properties to another table?
