Hi @Andrew_Milne,
Here are the two ways you can edit whether the “Add row” shows or not. If it’s not working this way on Safari, we can submit a but. Just wanting to make sure we’re looking at the same settings. And this GIF was done in Chrome.
Hi @Andrew_Milne,
Yeah, was aware of that option. Checked, and it is a Safari problem as fine on Chrome.
Another solid suggestion towards even greater usability within a team of non-makers who are using a doc…
Not sure if I’m being thick but has the totals row at the bottom gone now? Can’t find any options for it.
@Josh_Unwin1 hopefully this is helpful
Can the sum show just minutes and not change to houres?
