[Part Numbers].filter([Part Number] = thisRow.[part number text])
This works when I make the [part number text] field plain text and manually type in the value, but when I pull the value out of existing text, it no longer works.
The formula I used to take it from existing text is…
split(thisRow.Product, " ").first().toText()
This is the same formula I am using to create the part number as well, so I am not sure why the input to create the item cannot be used to search for the item.
It seems to have trouble with items that have dashes ( - ), but sometimes they work… It is super inconsistent. The specific data point that is currently not working is “596279-001”
Any ideas?
