hello
i want to get data from two table that match two columns not one column
for the following i want to get data from another table that match column project and column set items in two tables
what i get from filter function that data match one column (set items) and neglect column (projects)
I’m sorry but I’m not sure to understand what you’re trying to do …
Could you please share a screenshot of the problematic filter formula you tried ?
(Or, if you can, share an anonymised sample doc reproducing your current setup and problematic part of it)
So, like in your formula, we take the table Progress and we ask Filter() to look for the rows where the value in your look up field [Set Items] contains thisRow.[Set Items] AND the value in your look up field Project contains thisRow.Project…
And this should return in your Progress look up the appropriate row
The thing here (from what I can see from your screenshots) is that you seem to compare a text value to a row … which simply can’t work . In the formula I shared above I compare a row to another row …
I’m not sure if the sample you’ll find below reproduce 100% of how your doc works but don’t hesitate to take a look
I seem to have corrected the formula … Well, at least, it doesn’t throw an error anymore !
Due to the language barrier though, I just can’t confirm the results are the right ones
In a lookup field, you can only get the data from the concerned table
So, in your Progress lookup in your Set table, you can only get rows from your table Progress (where Set Items contains thisRow.[Set Items] AND Project contains thisRow.[Project])
Same goes for your view Inventory Transactions …
All I could do was to add a new lookup field from your table Inn Items to the Set table
